I have no problem putting in a roll bar (although for autocross it's more about keeping yourself in the seat than impact safety), but then you have to worry about padding the roll bar itself to keep it from being a danger during an accident on the street (ever tapped an unpadded roll bar with a helmet? Think what would happen to an unprotected noggin!). With that in mind, what do we start looking for in a roll bar?Kamin wrote:2) you need a rollbar to mount a harness properly. once you have one then we can talk. untill then im not saying because its more dangerous with a harness+ no rollbar than without a harness.
3)if you are having overflowing problems a PS cooler is a good idea, just get a generic small transmission cooler and make some hardlines with parts from autozone. i have very minimal overflow issues even while drifting on road courses.
Mike, i have to agree that a 5 pt. belt without a roll bar is not recommended. 240sx roofs are not as crush resistant in a rollover as say, a volvo. Although the risk of rollover is fairly low in autocross, you don't wanna be caught wearing a 5 pt harness without a bar in a rollover. You can't duck so your noggin gets crushed even with a helmet on . that's the danger. A short term solution until you get a roll cage might be a $20 torso harness, which is a simple quick release belt that wraps around the seat back. I used them at HPDE's in my old S13 which had the same non-supportive seats. worked surprisingly well. they are also popular among autocrossers.Vettedrmr wrote:
We haven't started autocrossing yet, so I don't know if we'll have a problem with overheating; that's why I'm asking the question now.
Thanks for the answers, and have a good one,Mike
http://www.autopowerindustries.com/Roll_Bars.htm is aboutr the only commercail one for a 240 I have seen. Or you can make one if you can weld, or know someone who can. If you plan on fabricating one, I would suggest following SCCA rules, as most other organizations accept their safety rules.Vettedrmr wrote:Bubba1,
Thanks for the reply. So, now back to roll bars. As I said, I have no problem installing one, but which one(s) should I look for and how did you go about padding them? Also, I assume that the rear seat is toast for anyone needing a ride.
Nothing at all. My son has just been out on a course a couple of times with an instructor, so right now I'm concentrating on driver support and reliability. Looks like there's a lot of body roll, but that's not necessarily a bad thing as long as the rest of the suspension is working.91rs13 wrote:What have you done for the suspension? Wheels tires? ( part of the problem with the Lancer---sticky tires / soft suspension-not good
