Got a few alarm questions
Post all your Nissan electronics, car audio and stereo questions here!
coastal6.0
Car: 08 pathfinder se v8, 06 f250 powerstroke
just installed a clifford solaris in the pathfinder today. i caught the domelight supervision wire in the a pillar instead of diode isolating each door, i'm just f'n lazy. once an hour the alarm goes off. the LED tells me the door trigger is setting off the alarm. just wondering if maybe the BCM is pulsing a check on the domelight wire? also the windows seem to pulse down when the alarm disarms, got it set to dbl pulse unlock but i also tied in the "pulse before start and upon disarm wire" with the unlock to disarm the factory alarm before the truck remote starts. just wondering if maybe that wire is extending the pulse a little too long and dropping the windows? plan on adding a channel expander to control the front windows from the remote. also added a DEI 530t to the rear windows to have 4 windows auto up/down. does anyone know of a current model nissan/infiniti w/ 4 auto windows, would like to purchase the switch. any comments would help. thanks
coastal6.0
finally got it figured out. i needed a door lock module to properly work the locks, DEI part # xk02. directechs recommended it but said not necessary. i found out the hard way. also i moved the door trigger wire to catch all 4 doors at the bcm, diode isolated them and no more falsing. this truck wasn't that hard of an install, so if anyone has questions about this vehicle or an alarm ? give me shout. also this truck was an early '08 model w/ a build date of '07/'07. all '08s list that the vehicle is prewired for sat. radio but i cant find the tuner or harness. does anyone know where the factory tuner is installed?
