Problem #1: Ok well since I raced my buddy's mustang the other day my car smokes every now and then when I stop after driving for a while, but i'm thinking its the turbo (the stock t25). I wouldn't say its only after hard boosting but definately after boosting. I'm thinking I might have messed up the oil seal in the turbo the other day when it overboosted, thanks to the avcr screwing up. I have been running it at 12 psi intermittentley for a about a month or two and the other day it hit like 14 or 15 psi and its been doing this since then. I don't think its the rings or ring lands because I it never goes lean or bucks in boost, in boost i see like 11.5 to 1 afr's so i know thats good. But anyway, when it does smoke its only for a few seconds once i'm sitting still and its a good bit of smoke, it never smokes when I'm flooring it, so I'm thinking there is oil pooling in the turbo??
Btw I did beat the 4.6 mustang gt that had full bolt ons and a rom tune =)
Problem #2: My avcr is working intermittently, I'm either at stock boost or my set 12psi. So i'm wondering if i should clean the solenoid or pressure sensor or what, because the control unit is definately ok. What do you guys think?
