got a clicky noise comeing from valve covers on the j???
kccake
Car: i994 infiniti j30
got a clicky noise comeing from the j!!! to me it sounds like an old 350 chevy i had that had loose rockers!!! or my 90 sho that had valve lash!!!big job on a sho when you do it yourself and looks even bigger job on the j more stuff to rmove intake!!!)do the j,s have to get valve lash done(shimmed)??? or could it be like i said loose rockers!!!it only does it at idle and low speed the faster i get it goes away!!! any idea or segestions would be great thanks kevin
driverdriver
Car: NICO's longtime resident Canuck!!!
Sounds like your engine solenoids. Somewhat common up here in the northern climes.
kccake
do you mean the coils??? on the spark plug wires??? if not where are the solinoids located at and how do i rull them out?????
driverdriver
Beleieve me its your solenoids. I've had to replace mine some years ago. I think every J owner in Canada has had to replace them at one point or another. The clicking will get much louder. Let me see if I can locate you a diagram. Unfortunatly fuzzycats.com is down.
driverdriver
The official name of that part is valve timing control solenoid
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
These go bad on the Z32s from time to time, apparently you can use the Q45 ones on the J.
kccake
so where are the silonids located are they exspensive????
elwesso
2007 BMW M Coupe
Theyre located on the front of the valve cover.
kccake
so do i have to rmove the intake to get at them!!! any idea on what they cost and where to get them??? thanks kevin
kccake
the only solenoid i can find at everything nissan is Fuel system - Fuel induction - Fuel injection - Fast idle solenoid!!!!is this the one or sometrhing else thanks
