got a 5 lug s13 with 300zx brakes???
glitched
Car: 1992 240sx se
)if you have an s13 with 5 lug conversion and 300zx brake upgrades, please post pics of your ride and info on what wheels your runnin. id like to get an idea of whats out there and what looks good for this option.
Edit: im looking at acquiring an extra set of rims to have a set for winter and summer, the set in particular are 16x7, +25 offsetthe rim is wider than my current s14 rims but still with in margin, but im not quite sure if the offset is ok?
SmithSR
Car: 240sx
OE struts with TT brakes f/r with Z32 (7.5" width only)wheels, tire sizes
205/55-16 F225/50-16 R
225/50-16 did not fit on front, and the 205 is VERY close. Still, the package will work(on OE style strut design) without spacers..
sorry no pics, a customer runs this kit
glitched
Car: 1992 240sx se
nobody has pictures?!?!?
carofchoice
Car: 91 240sx
here is my old car in the sig. 17 by 9's all the way around. cant remember the offset but i did have spacers. hks suspension
nismofly
Car: 89 Nissan 240SX Hatch
SmithSR is that on an S13 or 14? ive got a 13 and i just got 16x7.5 +22 wheels. i was hoping to get 225/50-16 all the way around. im going to get z32 brakes also, i know they fit and i know what they look like behind my wheels (sweet), but you bring up the tire issue, you think i would have a prob with those tires?
and glitched why behind 5 lugs? just because thats what you have? theres a few pictures of s13s on here with z32s i know, but they are 4 lug. if you want i can find them for you.
glitched
Car: 1992 240sx se
nismofly wrote:SmithSR is that on an S13 or 14? ive got a 13 and i just got 16x7.5 +22 wheels. i was hoping to get 225/50-16 all the way around. im going to get z32 brakes also, i know they fit and i know what they look like behind my wheels (sweet), but you bring up the tire issue, you think i would have a prob with those tires?
yeah i kinda just wanted to get an idea of what was out there, and people usualy upgrade to 5 lug for better wheel selections, so what did people select, and how does it look?
also im not an expert at all on offset, etc. so i also wanted to know what absolutely worked for sure before buying somthing (so i dont run into a problem like my brother had where his studs were to short for his enkei's)
SmithSR
Car: 240sx
It's on s13. The offset on the 7.5 Z32 wheels is +45 according to chet's sticky thread in the wheel forum.
225's rubbed the oem strut, 205's you could slide a toothpick in between but not a pen.. gives you an idea of how tight
a +25 gives you almost an inch of extra clearance on the strut. I'll bet it clears well. How will it fit under the fender edge though
nismofly
okay heres the wheels i got with z32s behind them. only difference is these are a different offset, but as you can see they also have 5 lugs, with the same offset options: +22 or +32. i got +22, these are +32, but you get the idea. this is on bronze mfp's car, its an s14. if you want the whole package, s13, 5 lug, and z32, the only one that comes to mind right away for me is ryan's car (ChunkiDori). i just cant find the exact picture of his car i think you would be looking for, but you can try...anyway heres the wheel/brake:
