Larz »
https://forums.nicoclub.com/larz-u216291.html
Sun Apr 13, 2014 2:44 pm
I would expect the G class to accelerate faster as well. The horsepower per ton ratio between the two cars clearly would favor the G class. Given the same conditions, same roadway, same crosswind, etc ... physics says that speed and inertia are proportional to 'the amount of mass' to which the same force is applied.
There is also something to be said for the age and wear levels between the two engines. a car with 400 miles and 3 less years on the road would be expected to burn fuel more effectively, have less gunk in the engine parts, and perhaps a tighter transmission. Then there is the gear ratio and tire size which I reckon is different between the two cars.
When I use a G class as a loaner, I feel the same differences. But that doesn't impress me because the rest of the car is so much 'less' in many ways: harsh ride, more plastic inside, less luxury, noisier in general on the road. And even with more acceleration, the G transmission is easily confused. It's as if the car isn't sure which gear to use based on what you do to the gas pedal - running quickly between gears before deciding which gear is needed.
The Q50s Ive driven are similar regarding harsh ride and a gear box that's frequently confused, but they are better looking and don't seem as 'cheap' inside as the G class.
Having blathered on about that, we also need to remember that the G-class is designed as a 'sporty' sedan and the M class is not (even though some claim it is). The M class is designed to be more comfortable / luxurious while providing good throttle response and good acceleration.
