And pretty much everything he said for the list..........Vkoslak wrote:First, research the hell out of it.and it will cost more than you think, even when you plan things out.
got a phone number? iam located about 21/2 hours above atlanta off of I-75 well lemme know1 do u guys do installs?takaramotors wrote:if you want a Rb20 We have a HC that just arrived you can come down and start it up. also we sell a full line up of parts for the RB motors as far as maintance and tuning it up. Just email US [email protected]
no answer from both numbers but do u guys install the swaps?takaramotors wrote:call me at 678-663-0579or derek 770-862-0022 most likely be able to reach him right now
email replied!takaramotors wrote:Yes we do the swap as well as sell all the parts check out your email.
thanx for the info! i been doing all the research i can!Chaos the Xile wrote:Like all the other suggestions, you should start off woth research, tons and tons of info lies dorment here in these forums, also wikepedia is a good source for info.
Next get the clip if this is the swap you want. Get the swap done first replace things like the stock clutch, you can get replacements from eBay, JGY, etc... Simple mods to do when your doing the swap:
Upgrade ClutchBlow off Valve Front Mount Intercooler3" ExhaustCustom DownpipeMotor MountsWater Pump Oil PumpGauges (Boost, Oil Temp, Water Temp, A/F Ratio)
Then move into bigger things once you get it running and get a hand of it:
Bigger turboBigger injectorsNew LSDSuspension ECU
Thats the best way to do it I think, and ask us were here to help too!
open down pipe yes u saw flameskoukicody wrote:that thing got a dump pipe where that cat usually is??? i saw some flammage
i have thought about the sr20 but iam looking to make a lil more power! around 300-350@the wheels! hopefully my swap will go a little better then ur experience has been! but anywayz keep me updated if u get an sr20 and lemme know what kinda power ur making who no's i may change my mind about wich swap i want!Sil240 wrote:I would of gone with a SR swap too if I could change things right now. I've spent a shyt ton of money and my car still doesnt run!!!!!I would be driving my car, having fun and making a shyt ton of power!!!!But....... I had to be differentIf you are interested I have a RB20DET bored .068" over, JE forged pistons, magged rods (ok), micropolished crank, Re-worked head and new valve springs retainers and water pump and oil pump and blah blah blah.I have TON's o stuff to go with it
Mo your selling the beast????What are you going to get?
