jeremyh »
https://forums.nicoclub.com/jeremyh-u155357.html
Wed Mar 03, 2010 10:25 am
Hello everyone,
First time poster to this forum looking for help.
I took my 2000 Maxima SE with 90,000 miles on it (original owner) into a local mechanic for several issues:
Clutch fluid leak (about a reservoir's worth per week)Replace drive beltsFlush coolantReplace rear brakes
The fluid leak was traced to the rubber hose that's found under the air intake. They replaced this hose. To replace the hose, they removed the air filter housing assembly. They also put in a new air filter.
I noticed my stereo had both the CD and tape ejected, and my radio presets were lost (power disconnected).
When I drove away, I noticed:
Car starts and idles smoothly, ~800 RPM.At light throttle, behaves normally. Sounds normal. Pulls normal.At mid to full throttle, does not have normal pull. RPMs match acceleration rate, which is slow. Feels like "half power". Car stutters occasionally while under mid to full throttle. Doesn't exhibit the same kind of engine howl as it spins up. Doesn't "kick" around 3000 RPMs or so, just keeps climbing at a boring snail pace. May actually be worse than light throttle in terms of power.
Took it back to the shop, demonstrated to the mechanic with a short drive. Mechanic then took it for a drive. His diagnosis is that the clutch is slipping. I called BS. We discussed extensively. Again, RPMs don't spin up faster than the vehicle acceleration. I know what a slipping clutch feels like.
He pointed out that if it was a breathing problem ("Did you leave a shop rag in the intake?"), the engine would hit a wall or sputter at the higher RPMs. The engine will climb to red-line under load, just slowly.
We both agreed that if it was a sensor issue, a connector not getting reconnected, etc, we should see a check engine light. (or is there something you can tell me to say this is wrong?)
Brakes fully release when I take off the parking brake, so it isn't something bad from the rear brake job causing major drag. (Although I did notice I have to pull the hand brake higher than before)
We looked under the hood together, didn't see anything out of place. We focused on the air box housing. Connectors were connected, everything was in place. Pulling the throttle under the hood resulted in an expected RPM increase. We didn't look in the area of the drive belts at all.
Primary symptom remains: Low engine power under full throttle, occasional sputters under half to full throttle, no check engine lights.
Since we were at odds, he said I should take it to the dealer and if they diagnose it as something they did, they will pay for it. I really don't have the time to do this, I waited 2 months with the clutch leak to finally do something about that. I'm hoping it's a simple "look for this hose or connector to be disconnected". Any thoughts on what the problem could be would be greatly appreciated as this one has me very puzzled!
Modified by jeremyh at 1:57 PM 3/3/2010
