Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sun Mar 14, 2004 7:55 am
1st gear is controlled electronically - everything else is linkage. I'd check 2nd to see if it'll hold in 2 at that position (after starting out in 2) - if not then it's probably something internal to the transmission or linkage. Otherwise, I'd suspect something in the 1st gear solenoid sticking that's not releasing correctly.
Just as a side note the transmission locks out 1st gear manual start in colder ambient temperatures before the car warms up. My dealership didn't know this, and before I learned it I got two warranty transmissions out of that!
Does the car drive normally otherwise?
He needs to buy my 1993 ECU/TCU combination that'll get him starting in 1st gear all the time! I just tested my spare set to Orlando and back and they work fine - so they'll be going in B/S/T in a day or two for $300 for the pair.
Heath
