Now, the car feels worse than it was with 2 bad ks. When you hit the gas, it basically just loses power. All power and it won't budge. This happened when i stopped at a red light. It also makes this weird sound, it comes from the under of the car when you press the gas pedal. Could it be the CATs?
That day, i kept getting some white smoke from the tail when I would start it up. It smells like coolant. And It drains the coolant also.
I did scan the CEL code and I got p1492. I checked fsm and can't understand what the problem is.
At this point I am just fed up with it. If anybody is reasonable enough, I will sell them my Q. I can't believe I just said that
