Good Way To Wire Fan
FinkenS14
Car: 1995 Nissan 240sx S14
Hey guys I got a 16" fan on my RB set up, and right now I have one wire grounded to the chassis, and then the power wire going into the cab, with a switch, and then right back out to the battery, so whenever I turn the car on, I just flip the switch and the fan comes on.
But does anybody else got any ideas?
crash n burn
Car: '91 Nissan LE hatch
'93 Nissan Silvia UDSM
'92 Infiniti M30
yeah, incorporate a relay
bersh240
EDIT!!!
ignore what i said.. thats a dangerous way to wire it.
TheRealNap0le0n
Car: 1998 q45
if you like fires or replacing switches leave it the way it is otherwise use a relay
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
FinkenS14 wrote:Hey guys I got a 16" fan on my RB set up, and right now I have one wire grounded to the chassis, and then the power wire going into the cab, with a switch, and then right back out to the battery, so whenever I turn the car on, I just flip the switch and the fan comes on.
Get yourself one of these. Don't cost much and is very effective.
example: http://www.marquisphotos.com/ZR2_Blazer/V8ZR2/2.htm
Easy to install. Adjustable, too.
kouki munster
Car: 97 base 240
I don't have much faith in those things, I've had one go bad on me and seen a few others crap out on some friends.
Redevil
http://www.kragen.com/ProductDetail.asp ... 00&PTSet=A
Been running this one and it has worked flawlessly and is easy to install
FinkenS14
TheRealNap0le0n wrote:if you like fires or replacing switches leave it the way it is otherwise use a relay
x2, I always thought this was the best idea that way at drift/autox/drag events I can run the fan with the car off. I got a big interstate deep cell running my car so that battery is a beast and never runs dry.
devlmaycry
Car: 95 Nissan 240sx S14.5
I bought the dakota digital one for my car. They have been making stuff for hotrods and customs forever now and have good quality stuff. It has a plug for triggering the fan when the A/C is on as well as a timer for letting your fan run for a set amt of time after the car has been turned off. If you have an aftermarket temp gauge like, an autometer, it hooks right up to your temp sensor and even comes with a relay. I have mine set for a dual speed single fan. I love it and I think I paid right at 100 for it. It's a compairable price to the DIF setups.
