Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Wed Aug 14, 2002 4:49 pm
Can you downshift? well then you will never have to worry about spool once your out of first gear, no matter if your road racing, driving around having fun, or drag racing. People always complain about lag, but why do all these road race supra's have a big single turbo..... because it works better. I have a motor that starts making HP at around 3500rpm, full boost hits around 5k. It will pull like crazy too the redline at 8k and no matter what gear I'm in it will not drop out of boost after it gets moving. Not to mention I enjoy all the benifits of a bigger turbo. I think the 3037 is a good choice, everybody and their brother is running a T3/T4 on 1.6 honda's, the 3037 is about the size of a big T3 on the exhaust side, and the compressor is rather large (slightly more than a T4) but you also have 400cc's more air spooling it. I honestly think anything in the GTiR turbo size range is only a "bandaid" because it's still limited by the fact that it's a small frame turbo, it has to spin faster to make the same boost, it has less 'bearing area' inside the CHRA so it will wear out sooner, and it makes more backpressure so it is going to cut engine life due to the higher EGT's. Look in Japan, nobody is running 'just' a little turbo, your always seeing big turbo's on the cars they have.
I'm not saying you need to go all the way to a T67, but calling the 3037 "too big" is not looking at the whole picture IMHO. Too many people have that australian point of view that anything bigger than a T28 is "too big".
