good transmission fluid
Tunerguy1989
Car: Nissan Pathfinder LE 2001
whats a good transmission fluid for a 2001 pathfinder 3.5L LE. what have some people used that are good for logevity and reliability. This car will be making lots of long trips not off roading so somethin with good stabel endurance would be great.
thanks in advance
Tunerguy1989
I have one more question does anyone know how much transmission fluid the 2001 pathfinder LE takes. I think I read 9 qts does that sound right? Its the automatic, 3.5L.
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
Check out the Member Recommended Fluids and Filters thread. I use Royal Purple Max ATF. Last time I used almost 9qts which was what I drained but I think it was overfilled by the person that serviced it last. I'd buy 9qts and only replace what you drain and return what's left over, or keep it for the next change.
Billy
Tunerguy1989
okay koo definitely thanks for the reply. Ya i tried that thread and it wasn't working ill try agian at a different computer. thx again.
Empty V
Tunerguy1989 wrote:okay koo definitely thanks for the reply. Ya i tried that thread and it wasn't working ill try agian at a different computer. thx again.
Just click the link in my post, it should jump you to it.
Billy
alexf20c
Car: '00 SE 4x4
the total capacity is close to 9qts, but you can not drain all of it unless you drop the transmission and pour it out of the torque converter. if you're just draining the pan, you'll only need about 6qts. i don't recommend "putting in what you took out." fill it until you get within the marks on the dipstick. go for a drive around the block and check it again.
pra_1979
Actually when I check transmission fluid with dipstick, I am not able to say what is exact fluid level. Stick comes out having oil with almost like 3 inches from end. I know that is not true as I just drained fluid which was around 5-6qt and I added 5qt back. When I say having oil with 3 inches from end, it is oil marks but oil thick layer is there only on the tip of end.
How you guys tell by looking at dipstick what is the correct level of fluid? is there any trick or something.
Motor oil dipstick tells exactly how much oil is there.
Empty V
pra_1979 wrote:Actually when I check transmission fluid with dipstick, I am not able to say what is exact fluid level. Stick comes out having oil with almost like 3 inches from end. I know that is not true as I just drained fluid which was around 5-6qt and I added 5qt back. When I say having oil with 3 inches from end, it is oil marks but oil thick layer is there only on the tip of end.
This is exactly why I put in what I drained. When I dropped the plug for the pan I got almost 9qts, not the 6 that Alex is claiming. I suspect it was over filled but not by 3 quarts.
Billy
pra_1979
Billy
If we rely on only what is drained, we are assuming previous fluid level was correct, It might be previously it was overfilled or below minimum.
When I did drain last week, I am sure fluid came out was around 5-6 qt since I used milk container to store fluid and it was around 1 and half milk container. This is for 2003 Pathy SE. I bought it used around 6-7 months back and thought of changing fluid. But not sure previously fluid level was correct or not.
WPGQX4
Car: 1998 Qx4
Why not add just a bit less than what you drained. Check level. Add if needed. It has a dipstick for a reason. Amsoil has the total fill of the 3.5 and the 3.3 at 9qt. I thought alex had this figured out on the 6th reply.
pra_1979
WPGQX4 wrote:Why not add just a bit less than what you drained. Check level. Add if needed. It has a dipstick for a reason. Amsoil has the total fill of the 3.5 and the 3.3 at 9qt. I thought alex had this figured out on the 6th reply.
"Check Level" is the step, I am finding difficulty with.. I am not sure how to read dipstick. Its having fluid all over it.
fleurys
Car: 2001 Pathfinder , Locked and loaded !
try again until you find a way that you are able to read it.... there is no real trick for this... it's not like it's going to be clear like black and white... you will have to figure out what is the oil that is from the trans level and which one is just splashed on the stick..
If it can help, also, try reading it when the engine is stopped. Once you stop it, clean the stick and put it back in and wait 10 minutes. if you remove it slowly, you should see a clear separation between the red of the oil and the silver of the stick.. also since the engine is not running, there should be less splashed oil on it.
alexf20c
Car: '00 SE 4x4
are you wiping the dipstick before you read it? make sure you wipe off all oil from the dipstick, then put it back in, all the way down, then pull it out again.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
Well one thing that sucks on our cars, is that you have to fill the fliuid through the same whole that you check the fluid with
Once you put oil in and get the inside of that check tube coverred in oil, its gonna be oily and give false marking for a while
Wish there was a better way to fill
alexf20c
Car: '00 SE 4x4
most vehicles refill fluid through the transmission dip stick. on many FWD transaxles, there is not even a dipstick. you have to reach down to the case and remove the fill plug, and use your finger to check the fluid. and when you refill it, you're left to your own devices on how to get the fluid down there without spilling.
we're very lucky to have a trans dipstick tube and a drain plug on the pan.
infiniti97qx4
Car: '97 Infiniti QX4
the way i do is this:
replace every 2 years 5 liter oil from oil pan.cause can reach the rest of oil on the back.REMEMBER HOW MUCH YOU DRAIN THAT MUCH PUT BACK IN.
over 10 years using Syntetic MOBILE 1 ATF fluid in my old pathfinder and now countinue tradition with qx4 .never had eny problems.
pathfinder sold at 360000 still running good with new owner close to 400 000 km ,and qx4 pushing 260 000 km using only this oil ,not any additives or any other chemicals.
also i have put on the bottom of the oil pan 3 o-ring magnets just in case if it any metal particales in trany to holdem down.
good luck
alexf20c
Car: '00 SE 4x4
you should really stop posting.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
alexf20c wrote:you should really stop posting.
:confused: :confused: :confused:
