GOOD TO SEE A RENAULT IN NISSAN SKIN.....
RENAULTNISSAN
Car: 2003 M45 TECH/2006 ARMADA LE
THE VERSA IS A CLIO FOR ALL INTENSIVE PURPOSES, RIGHT???
WHERE IS IT PRODUCED?
Nope.
Tiida (pronounced "tee-da").
Built in Japan.
p.s. "intents and purposes".
Welcome aboard, fellow Phoenician!!!
voltronguy
Car: 2007 Nissan Versa SL Super Black
While the Versa is a Tiida, the Versa is made in Mexico.
http://en.wikipedia.org/wiki/Nissan_Versa
motoguy128
Car: 2007 Nissan Versa S - 6 Speed
Yes, the Clio shares the Nissan/Renault "B" platform. It also uses the Renault designed 6 speed transmission, and the MR18DE engine is a joint Nissan/Renault design effort. In Europe, the Clio typically gets a more effecient turbodiesel or smaller gasoline motor. The MR18DE is used on larger B platform vehiclesthat are like small minivans. I forget the names.
Oddly enough, the styling of the Versa shares a lot of traits with the Magane (which I have driven), but it's on a larger platform.
The Versa is built in Mexico, but after installing new speakers, I think some of the interior body panels may have been molded and/or assembled in China based on their inspection stickers. Not suprising really if they were.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
^ Correct.
The Clio is closest to the Micra (March) as far as it's Nissan-labeled cousins.
Nissan and Renault have done some interesting things with the little B platform, namely the Clio V6 24 and Micra R, both of which are powered by tranverse-mounted rear engines which drive the rear wheels. The Clio has a V6; the Micra a turbo 4 (QG20DE, a larger version of the current Sentra powerplant) and later a VQ35DE V6 from the 350Z (The V6 version called the Micra 350 SR).The Clio is actually a production model, while the hotted up Micra versions never made it into showrooms.
Clio V6 24
Micra R
RENAULTNISSAN
Thanks for the feedback. It does look like a clio at first glance. How integrated are the compnies yet?
OKVersa
Car: Nissan Versa
When showing off our car, a friend of ours, said, "Wow, I had a Renault, once." I said, "This is a Nissan." He said, "Oh....."
