Our closest match bushings would be the subframe collars and those are aluminum.Def wrote:Question - how are the subframe spacers in that kit different than the subframe collars that SPL sells?
That kit almost looks worth it even if one isn't going to be using the suspension arm bushings in the rear or something like that. The steering rack, Front LCA and sway bar bushings seem like they'd be near as expensive as the kit when sold separately. At least from what I've seen.
