Good suprise while changing fuel filter
Cris78201
Car: 2001 Pathfinder 2wd 3.5 LE Silver
I just got this truck in June, I love it, so I'm changing the fuel filter assuming its probably never been done. I'm trying to get it out and my hand is hitting this lose bar........it's the sway bar :wtf2: it literally cracked in half...... :tisk: so now I'm looking for one, I don't even want to know what the dealer wants for it, and here in south Texas it's practically in possible to find a r50 to pick apart, anyone have any place online I might be able to get one from :confused: I found one website but I'm not sure about it
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
You may not know this website since your new, but CourtesyParts is a dealer in Texas ( maybe even close to you im not sure, check their location ) they offer in store pickup so you can save on shipping, but alot of people on here use it for OEM parts.
Since there really arent to many aftermarket options for the r50, and im sure you just want a OEM replacement, they have it for $133.
Heres a link to the part, you can see in the table your pathfinder specs as per what you put in your profile here - 2001 2WD 3.5L, it is listed in the 5th row from the top if you are paranoid about it being the wrong part or something.
http://www.courtesyparts.com/56230-rear ... _4800_4804&
EDIT: Also to be 100% sure, the bar you are talking about is the one that runs in FRONT of the rear axle if you are looking at the truck from behind, and also that it is not one of the swaybar links holding the swaybar, there is 1 on each side. Taking into account your sway bar is broken, im assuming it was due to something extreme happening, either offroad or a huge pothole or whatever from the previous owner, i would also change the sway bar links while your at it, and the bushings.
For those things i would recommend going to advance auto and ask them for MOOG rear sway bar links, and bushings. There are a total of 2 bushings for the sway bar. MOOG's are an aftermarket replacement to the OEM but they are a bit better, and also they have grease zerk fittings on them so you can use a grease gun to prolong the life of the mini "ball joints" that hold the sway bar.
Cris78201
Thanks Miami yea I'm going to get it from there, that place is about 5 hr away from me so I'm going to have it shipped, the links are a little worn to so I will be replacing those and bushings. It's weird how it's cracked in half like that, everything else seems to be ok, I've never seen one like that thanks for the info though
ferrariowner123
Car: 1996 Nissan Pathfinder SE
:worthless:
This is definitely worthy of posting pics, i want to see this!!
Sorry for the car trouble, that always sucks.
Good job staying proactive on maintenance though. lol
-Kyle
Cris78201
Pics coming soon
01silvapathy
Car: 2001 Pathfinder LE 3.5
Lol, I cut my swaybar in half to get it out close to 4 years ago and havent looked back since.
lzrj
Car: 2004 Nissan Pathfinder LE
Well I'm bummed after reading your original post. You title it "good" suprise. Should of left good out and said surprise. Sad to hear it was another problem. Was hoping to read something positive for once that happened like you found $5,000 where the fuel filter should of went. Now that's a good surprise. :)
