From what I read, the Y33 (97-01) Q45 rotors are a good replacement, considering its only a 2mm difference.
( R33 GTS-T = 296mm x 30mm / Y33 Q45 = 296mm x 28mm ). The 2mm difference is negligible.
Now I'm searching for a decent slotted rotor for the Y33 Q's. I did a search and what came up were either cross drilled & slotted or blanks, neither of which I'm looking for. I could go blank, but since I'm replacing rotors anyway, I might as well do a step above upgrade. This is for DDing and slight weekend track use. I know good blank rotors for Q's are Centric Premiums, but what brands out there are good for slotted rotors for the Q's? Suggestions?
