Good size?
NewToVersa
Want to buy wheels. Will P215/45R17 on a 17x7 42offset fit...
CodeRed
Car: 2008 Nissan Versa S MT
First off, welcome to NicoClub! and secondly, yes those will fit. In fact, thats the same size I'm getting.
NewToVersa
Thanks man... post a pic please
CodeRed
Your welcome. Here is exactly what im getting. Enkei Evo 5 wheels 17x7" with Hankook K106 tires 215/45/17.
NewToVersa
With the tire mounted... ouups you dont have those now right...
CodeRed
I'm getting them
NewToVersa
my bad
NewToVersa
Thinking of those http://www.tirerack.com/upgrad...+Gold
Modified by NewToVersa at 1:02 PM 9/29/2007
CodeRed
Your link doesn't work.
NewToVersa
CodeRed
that's a 5 lug bolt pattern, the versa uses a 4x114.3 lug pattern
jfanaselle
Car: 2007 Nissan Versa Hatchback SL, 2008 Nissan Rogue SL
Hey CodeRed... I searched but I found about 6,000 threads and none of them seemed to have the answer I was looking for. Do you think a 7.5" width with the same offset (42mm) would fit ok? I wouldn't think a 1/2 inch width would make a big difference, but I just wanted to be sure. I'm thinking of getting the Falken Sceptor wheels. They're cheap, they look great and they're not too heavy (25 lbs), but they're not the lightest things around either.
NewToVersa
They make it in 4 bolt too... wrong pic
NewToVersa
youre kidding right??? 25 is heavy man... shouldnt be more then 20lbs
CodeRed
jfanaselle wrote:Hey CodeRed... I searched but I found about 6,000 threads and none of them seemed to have the answer I was looking for. Do you think a 7.5" width with the same offset (42mm) would fit ok? I wouldn't think a 1/2 inch width would make a big difference, but I just wanted to be sure. I'm thinking of getting the Falken Sceptor wheels. They're cheap, they look great and they're not too heavy (25 lbs), but they're not the lightest things around either.
To be honest, I don't know. I really do think a 7.5" wheel would fit fine but I really couldn't tell you.
Clipsed
Car: 07 ALL BLACK Nissan C11ST, 01 Mustang GT Vert, and 94 Suzuki Sidekick JX 4x4.
if you go 7.5, I would suggest a 35 offset or so to accomodate the extra width. You have to also compensate what tire you are going to run.
jfanaselle
I know they make a 4 lug, I just searched google to find a pic to post, and the only good pic I could find was that one. Anyways, they only make a 40 and a 42 mm offset, so I guess I should go with the 40 to help with the width. I planned on running exactly the same tire as everyone else in this thread, 215 45 17. As far as the weight, I just figured I'm adding weight for the size of the wheel, but I'd be dropping a little tire weight. I guess I could stand to go a few pounds lighter, but I really like these wheels and I'm certainly not looking for performance, I just don't want it to be slower than stock.
Clipsed
remember more weight=lost mpg.
NewToVersa
the wheels im getting are 16.8 lbs and tires are 19 lbs = 35.8 lbs im sure it's lighter then stock. Buying a heavy wheel on a fast car is okay, but not on slow car.
Anybody knows the stock wheel and tire weight?
MIdnkight-lude
i test fited my old velox onto the versa, and it seem fine.
they were 17x7.5 running 215/40/17 nitto. but one thing to note is that the wheel seem much more smaller then stock. so i your choice of 215/45/17 will prob be the best bet. i am prob going to look for a 205/50 cause i am looking for a nice set of light 17x7 rims. plus 215/40 had such a thin sidewall that i bent the rim ridding over pot hole ALOT.
NewToVersa
You know with that size your speedo will be off by 1.6mph. Sidewall should be 4.1 inches. But with 215/45R17 it will be off by 0.5mph and sidewall is 3.8 inches. With youre old setup it had only 3.4 inches sidewall.
MIdnkight-lude
NewToVersa wrote:You know with that size your speedo will be off by 1.6mph. Sidewall should be 4.1 inches. But with 215/45R17 it will be off by 0.5mph and sidewall is 3.8 inches. With youre old setup it had only 3.4 inches sidewall.
like i said, my old setup was from another car. so of course, it look funny, and i wont use it. plus the new wheel i plan to get will have thicker tires because i hate getting bent rims. so in theory i will be going slower. :p
VersaTiidaMX
Car: 2007 Tiida Sedan 1.8L, 6-speed Manual, Brilliant Silver, Tinted Windows.
Does anyone know how much do the stock steel wheels weight?
nissantech06
Car: 2007 Nissan Sentra S 2.0
The recommended tire size for the Versa in 17" form is a 205/45R17. Like stated above, the speedo will be off a couple MPH, and you also run the risk of rubbing the strut towers.
The 15" aluminum Versa wheels feel lighter than 20lbs. FOR SURE. I've done tires on them and I can frisbee those damn things.
NewToVersa
Yes... but they do recommend ( 215/40R18 ) 215wide as to fit...
nissantech06
Yeah, for 18" wheels, that compensates for the 1" larger diameter rim and larger width. It's all mathematical.
