Good size and offset on the s13
1990nismo!
Car: 1990 Nissan 240sx
Just bought my 2nd 240 guys need sum opnions on rim sizes
adrianfromthecastle
Car: 1992 Nissan 240sx
17x9 +20 all around
ashibah83
Car: 93 SUPA BLACK COUPE
simmode1
Car: Red '95 S14
adrians_s13 wrote:17x9 +20 all around
This man ain't neva lied. You might be able to run 255/40 tires all around with square fitment depending on which brands you go with.
AZ89two4Tsx
Really depends on the look you're going for and wheel style.
1990nismo!
ok well i dont wanna look ricey..... i want my rear rims with a bigger lip then the front a** well as da width..... i dont want sumtin huge...... 18 mayb 19 dependin how the rim is....... actually i was hopin anybody had nice pics.......
stantheman
Car: 92 240sx
18's look too big without a nice kit and 19's wont fit without a huge pull and roll and a tuck, stick with 17x9 +20's like he said.
1990nismo!
ok how would those look? any pics? this is my car now these rims came on the car [IMG][/IMG]
simmode1
Car: Red '95 S14
1990nismo! wrote:ok how would those look? any pics? this is my car now these rims came on the car [IMG][/IMG]
Car = good, clean start.wheels = Oh dear God... Why!? Those are Battleship sunk...
This may help you...http://www.rimtuck.com/thumbna...r+asc
The tricky thing is to figure out what you can fit flush under stock fenders and whether it will require things like rolling or pulling.
Also, the reason most ppl will recommend that you put no larger than 17's on an s13 is that the stock wheels are 15's. And for every size you increase your wheel's diameter, you need to decrease the profile of your tire. This is so that your stock gearing won't throw off your speedometer.
For example: You go +1 over the stock 15's, giving you 16's. The stock tire profile is 60. So you need to come down to a 50 profile to keep your total original diamater the same. With +2 size wheels, you'll be rocking 17's, and you'll want 40 profile tire usually.
If you go any further, like to 18's, you need even lower profile tires, like 30 profile, really. But that is really uncomfortable to drive on. Even 35 profile is uncomfortable IMO and both will throw off your speedo a little.
17's with 40 profile tires is generally considered to s13's sweet spot. Just be sure to get them with good widths and offsets too, to be flush with your fenders.
Good luck.
Modified by simmode1 at 3:38 AM 3/25/2009
