C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Jan 11, 2003 11:29 am
Why wouldn't the turbo be able to keep up? Once the intercooler and piping of a turbo system is filled up, the turbo should have no problems putting out the same airflow. In fact, depending on which dimensions are made bigger, the I/C may actually offer less of a pressure drop and allow the turbo to boost less to make the same manifold pressure. This would equate to better overall efficiency as well, since the air coming from the turbo will be a little cooler.
As far as lag, how much bigger are we talking here? Keep in mind that flow has nothing to do with the overall size of the I/C itself. It's the cross-sectional area of each channel, times how many channels it has that makes the biggest impact. And even if you add a few more channels to an intercooler. Do you really think there is that much volume to deal with? Adding a few feet of piping would probably be more than the volume from adding a reasonably sized FMIC. And adding a few feet would have only a slight effect on response. Throttle response does not change from any of this since it is only the measurement to how the engine responds to throttle inputs. I think Boost response is the word you are looking for. And there should be little to no noticable change in response either.
I'd look more at the cost-benefit of blocking some of the airflow to the radiator and increasing the temperature of the air that flows through it, and the performance gain from the added airflow obtained from using a FMIC. If I could get the same efficiency and flow from a sidemount as I could a front mount, then I would go with the sidemount to avoid blocking the radiator. But in most cars a sidemount tends to have much less airflow and is limited in size.
