z32pilot62 wrote:Do like a friend of mine did, buy a double barrel and cut it down to the stock. Reload one shell with rock salt and the other with buck shot. Load the rock salt round in chamber one and buck shot in chamber two. If they can bring themselves to get up after getting shot with rock salt they WONT have what it takes after the buck shot.
Nope. screw rock salt or less than lethal. You're protecting yourself not breaking up Occupy protests.
while there's some nice double barrels on the market, most are gonna run 400 bucks for a halfway decent one.
Honestly, the best bang for the buck is to look for a used Mossberg 500 or Remington 870. Get one with a short barrel and full stock. Pistol grips aren't fun to shoot and difficult to aim. Despite what you see in movies, shotguns MUST be aimed. in a distance of 15 yds (longer than any hallway in most homes) most buckshot loads won't spread more than 10 inches.
If you want a new shotgun, check out a Mossberg Maverick 88. You can find them for 200 bucks, they have a huge aftermarket for stocks and accessories should you feel the need to change things to suit you better and it's built around a proven design (the 500, there's some differences between the two models though but either is a fantastic gun for the money)
If you have to use it for protection, the adrenaline dump will most likely cause you to barely notice the blast from it.
I personally own a Mossberg 500 that currently wears an 18.5" barrel that I put a Meprolight front night sight on (these are about 30 bucks and not hard to put on if you have basic mechanical skills as you may need to fill the threads down so it's not sticking in the barrel.)
I've had it for I think 17 years now. It's seen a lot of abuse in it's life. The only thing ever to give me issue is the tang safety (it's on the top of the receiver, great for south paws and very fast to engage with your thumb). After so many rounds through it they'll start slipping under recoil. You can rebuilt them with a parts kit for about 20 bucks and 10 minutes of work. Lemme see if I have a picture of it...
I'd recommend a 12ga as there's MUCH MUCH more options for good personal defense ammo. If you're timid about recoil you can get reduced recoil buckshot loads for them as well as recoil reducing stocks (these aren't cheap, a good KNoxx Spec Ops stock will run around 150 I think but usually cuts felt recoil by nearly 30%) and most accessories are made for the 12ga models only.
That's how my Mossberg currently sits. I don't need much more really, I might have a shell holder that slips over the buttstock...but that's about all else I'm gonna put on it.
And yeah, I'm familiar with doubles too
