sure....
Injen Intake, - cold intake systeM? or short ram? Cold intake systems tend to make more power under the right conditions, but get dirty faster and usualy require some sort of cutting/molding of the car.
Apex N1 Exhaust- sure i guess, exhausts in general add 4-5 hp.... depends how large you go, too large and you lose low end torque, but gain it up top,
Hotshot Headers- adds for nice flow, usualy a popular among nissan drivers
Camshaft- well what camshaft are we talking about? a 250 or a 280?? you want a turbo friendly motor that makes power down low or a NA beast that makes power on top?
Cam Gears- how much do plan to advance or retard?
and High Flow Cat or Downpipe- this is usualy gray terretory and just increases air flow, nothing too big, usualy only needed if your breath in more air, cuz oyu need to spit it back out at the same speed.
35 hp? maybe, maybe not, strap it on and see for yourself, you also have to customize the engine to your own needs, and in my opinion you forgot one of they key parts, an modified ECU, something that you should think of first, if not a stand alone management system and enough reading so that you can operate it blind folded.
and as a warning to the next person whos thinking of a post like this, DONT DO IT, its worse than a sr vs ka post!!! takes diffrent strokes to move the world, want to know how much power a modification gains? try it out. Ive seen a magazine report a 16 torque gain from a simple intake system
