Good place to buy z32 brakes?
frsh13
Car: 1991 240sx coupe
Anyone know a good cheap place or website to buy all the stuff i would need to convert my front brakes to 30mm z32 brakes? If its reasonably priced maybe i would even consider getting the rear kit also.
thanx guys
Shift_Red
GrubyFngaz
Car: 2001 Infiniti QX4
Go to autozone and buy them. Then take back your 240 brakes for the core charge. That's the cheapest way I have heard, for new ones anyways. Used, probably e bay.Josh
frsh13
hmmm autozone.................aka bump
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
boost designs has a brake kit thats nice.... you should check them out http://www.boostdesigns.com
cville300zx
Car: 1990 300zx 1993 240sx
Z1 motorsports or autozone.
Chingon
Car: 1991 and 1992 hatchbacks
definitely local yunkyard.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
Chingon wrote:definitely local yunkyard.
I second that, I got my aluminum rear calipers and e-brake setup with cables for less that 200, another 100 more would have got me front calipers, but they were all sold out. I went to advance and got rebuilt front calipers for ~$320I almost **** my meal over that price. That and my dumbass ordered the iron calipers and not the aluminum :-/
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
The iron are better for preventing rotor warpage. I've had a 91 300zx with aluminum calipers, warped rotors 3 times.
On my 94 300zx twin turbo, I have never warped the rotors.
Which one do you think I drive harder and brake harder in?
Plus by getting iron you know you have 30mm not that crappy 26mm stuff that was only made 1 year.
Just my thoughts.
Chingon
you should stop buying crappy rotors then. Calipers have nothing to do w/rotor warpage..
574-240sx
Car: Nissans, Toyotas, Subaru
Take back your stocks for cores to Autozone and make sure you get the aluminum 30mm. I think it turned out to be a little over $100 after the return of the stock cores.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I got my 26mm aluminums from the junkyard for $25 each...
Some bead blasting and a seal kit and they are good as new!
Chingon
^^hehe i reused my seals...and I got all 4 corners + rotors for 100$. Take that for bargain!!
Bronze MFP
wow, i gotta get me a bead blaster. those calipers look brand new.
phuphyter
Car: 2002 Infinity G20
Won't they know that they are not 300zx cores though? And I thought S13's are supposed to get the 26mm brakes.
brisknfade
Car: NB8C FTW
Sometime they dont care if they arnet the same or not. I work at autozone and alot of the time, as long as you got something they dont care. Hmmmm, i should think about using my 20% discount on some of those calipers....
