"rbsileighty wrote:You get what you pay for... run the stock interheater until a good setup is in reach
I'd recommend buying a good core and making your own piping... or have it made... most of the piping kits "work" but you're better off making your own.
A core made for the S13 will/should mount correctly with the hardware provided. My R33 core/kit (Hybrid) required me to make my own mounting setup...
tintdude69 wrote:ya the battery is still in the same spot. everything bolted right up and you have to trim the bumper as usual. you cut like 5 inches below the battery. you do have to use the stock cold pipe pipe right off the crossover pipe and that connects to the new pipe going down into the intercooler. heres a picture of how the pipes run from the intercooler. the cold pipe doesnt go straight up through the battery tray like an sr kit does. thats about the best view of how goes through. its a tight fit between the motor and rad with a stock rad so if your planning on getting a bigger rad your gonna have to beat the pipe in a little bit. i got a 3in thick rad and had to but im sure with a 2.5in you wont have any problems.
http://i6.photobucket.com/albu...5.jpgh ... bu...1.jpg
is that the kit for the r32 or for the s13?
Modified by tintdude69 at 7:22 AM 9/20/2007
Like lilskyline asked, is that the kit for the s13 or the r32?tintdude69 wrote:ya the battery is still in the same spot. everything bolted right up and you have to trim the bumper as usual. you cut like 5 inches below the battery. you do have to use the stock cold pipe pipe right off the crossover pipe and that connects to the new pipe going down into the intercooler. heres a picture of how the pipes run from the intercooler. the cold pipe doesnt go straight up through the battery tray like an sr kit does. thats about the best view of how goes through. its a tight fit between the motor and rad with a stock rad so if your planning on getting a bigger rad your gonna have to beat the pipe in a little bit. i got a 3in thick rad and had to but im sure with a 2.5in you wont have any problems.
Hey man, is this the exact kit? http://xs-power.com/nissan/nissan007.htmlDriftX wrote:xspower (SSAC) makes a kit for 170 shipped, which is cheap as hell. The kit aint bad for the price and thats what Im using. It requries that you enlongate the stock airbox hole and drill a 3in hole under the battery tray, but no battery relocation is neccessary.
Heres how mine is setup.
The one for the skyline? What exactly do you mean elongate the stock airbox hole? I might get that kit if thats the one, I am looking for a relatively cheap solution and you cant beat that for 170. That core looks quite large, notice any lag while using it? Thanks
