Did you resurface the block and head along with the upper and lower timing covers? They all need to be resurfaced together (lower timing cover bolted to block, upper timing cover bolted to head) for a flat surface.Florida240sx wrote:Next time I beleive I'm going with a felpro. My cosmetic has given me problems....
Good input. I was leaning towards the cometic one but I dont want to have to re-tune my car since I just did that like a week ago.Florida240sx wrote:Next time I beleive I'm going with a felpro. My cosmetic has given me problems....
I might just go ahead and do that. Are you still running that same gasket? If so... how's it holding up?PapaSmurf2k3 wrote:when I asked this question a couple years ago, I was told that stock should be good to like 375whp or something. I went stock.
Cool...thanks. I'm going to go ahead and replace it this weekend with a stock one. The one on mine is probally the original one and it lasted through about 10,000miles of boost.PapaSmurf2k3 wrote:well, there are maybe 1000 miles on it, but its holding up good! I'll let you know exactly whats up when I fly back home in August.I'd say if you are using stock rods, you might as well use a stock HG.
HAHAHAHAHAHAHAHA...nissanfanatic wrote:Cometics don't suck. User error is the cause of their malfunction.. They aren't going to seal if your head or block looks like a Ruffles chip..
Yea I can read. You say it sucks to do the work properly..?? Nice...Chezedik wrote:Can you read? I said that it sucks to have to do the work properly. ****, do you work there or something? You know, making a ton of horsepower doesn't make you the end all-beat all KADET master. Calm the **** down.
Just to correct this, torque would be the determining factor in when the HG would give out. Cylinder pressure is what causes the failure. Assuming no abnormal conditions, torque is a direct reflection of peak cylinder pressure.. Peak torque means peak cylinder pressure..PapaSmurf2k3 wrote:when I asked this question a couple years ago, I was told that stock should be good to like 375whp or something. I went stock.
