Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Dec 24, 2004 3:23 am
Spring stiffness does not control weigh transfer only center of gravity divided by wheel base set the ratio. Body dive - rise just shows what's happening.
Soft springs, stiff springs, or body welded to suspension transfers the same weight to front tires..........ultimately.
Stiffer suspension or no suspension will have less [no] suspension camber gain so assuming the camber is correct -0.7 degrees static.........the less camber gain the more rectanglish the tire patch stays........a trapezoidal [from too much camber over heats the inner tire edge causing it to overheat [burn] and reduce friction..........it quickly goes thru the 200F optimum [summer tires] in the first second of a 2.5 second stop.
Lowering increases camber so braking may be less----- unless you correct extra camber created by lowering.
Not sure of the ratio as what counts is the total negative camber under load..........when the 26/120" ~~=22% weight shift at 1 G ~~= 435 pounds pivots forward on 146lb/in x2 springs..........435/292= 1.5" suspension compression..........the static camber increases by ~~1.2 degrees to the already 0.7 so what does your specific tire lose with 2 degrees negative camber vs. a lower stiffer sprung Q with -1.5 degree static camber and say 1.1 degree camder gain ~~2.6 degrees loaded camber.
My guess is an Eibach equpt Q [without camber correction] brakes worse than a standard Q [2 degrees camber vs. 2.6 degrees] as the front springs are only 15% stiffer thus the dive will be 1.3" vs 1.5" stock.
Lots depends on tires ability to handle braking heat.
Toe changes from level static to rolling to braking is another situation....... all depends on the contact patch shape under the extreme braking load......turning and braking is too complex for this discussion.
The better the tires the few and shorter the ABS pressure shut downs are thus the braking improves........... why some tires stop in 110 feet and some need 130 feet on the same car....................wet braking is a better measure than dry braking........see tirerack test.
Some tires stop from 50 in 110 feet some 100, some 90 some 88 on the same car...........22 feet difference from only 50 wet can you imagine 70 mph.
You get what you pay for [if you study this parameter]........most trade wet braking ......Some like Aqua tread 3 are awful in wet braking but the advertising lies to you in a legal way...........watch out for the words...Aqua, hydro.
