Hey Vin - Welcome to NICO.
For the 91 model, you want to upgade to the Phase II injector used in the 94-96 model. A significant design improvement was made on the Phase II injector.
With that said, you also need to upgrade the injector rails to a Phase II rail and wiring plug.
When I replaced my originals last summer I went with BWD (black dots) for a 94 model which are about $130 now days.. Sometimes you can get a parts store like OReiley to "cut you a deal" at $110.
One of our NICO sponsors, DeatschWerks in OKC, sells an adapter kit so a 94 injector can be run in 91 model. I run the DW adapter kit. Also, I understand DW has some "good pricing options" for Phase II injectors. Many members have had success with DeatchWerks.
I would give Chris at DeatschWerks a call to see what kind of pricing options he has to get your injectors upgraded to Phase II. Also, ask about ethanol compatibility.
http://www.deatschwerks.com/q45
Be sure to pressure test the injectors in the rail for any o-ring seepage before you start bolting down the rails as in the picture below.
