GOOD DRIFT COILOVER ?
Donkey Kong
Car: 240
what is a good coilover for drifting thair has got to be something cheaper than TEIN super drift. what spring rate and stuff like that am i looking for and has anyone drifted on the godspeed coilovers
E7-S14
Car: ess 14 foo!
you can drift on anything if your good enough.
A half a$$ed response to a half a$$ed thread...
Kckouki
Car: '97 Nissan 240SX
K-sports.
smocan
Just get 4 solid metal cylinders... weld them in where your suspension goes.
These threads will never end. But they should now that I gave the secret answer.
E7-S14
Car: ess 14 foo!
okfor serious.
if you wanna drift for cheepgo Megan Tracks.
i have personal experience with them along with a few guys that drift on them regularly.they all loved them.their great for drift.
thread end/
Donkey Kong
Car: 240
QUOTE=smocan]Just get 4 solid metal cylinders... weld them in where your suspension goes.
These threads will never end. But they should now that I gave the secret answer.[/QUOTE]
ok im really sorry i havent been on this forum for like 4 years and seen all of the suspension threads but like i said has anybody used the godspeed's for drifting
E7-S14
Car: ess 14 foo!
ive ridden on godspeed susp. in a friends car.and the ride was very inconsistent.compared to other coilovers ive ridden in.
it was extremely bouncy and sometimes even slightly unpredictable
i would skip the godspeed.personal opinion coming from experience.
but like i stated earlier. a good drifter can drift on just about any suspension.
Donkey Kong
Car: 240
E7-S14 wrote:ive ridden on godspeed susp. in a friends car.and the ride was very inconsistent.compared to other coilovers ive ridden in.
well clearly im no great drifter but thanks positive input i guess ill spend a little more money
Still NA
JIC Magic FLT-A2's.
adrianfromthecastle
Car: 1992 Nissan 240sx
coilovers with spring rates as high as 10/8 kg (front/rear) are intended specifically for drifting. Aim for coilovers with similar spring rates.
crackler
Car: ZOMG JDM TYT3
Revalved Koni's yellow's and G/C with spring rates that adrian suggested. . . . wait. . . .cheaper than tien . . . never mind.
Or full blown Koni race . . . wait. . . .cheaper than tien . . . never mind.
Guess it's JDM tyghtness crap for you.
Sorry, I had too.
What does 10 / 8 kg translate into lbs's as???
ChampaignSilviaS14
Car: S14
Your best bet is to go with Parts shop max ( powered by max )
the spring rates are 10/8kg, same as super drifts, its also what I run.
they are 1,000 dollars, here is a link http://www.gtfactory.jp/cms/page.php?9
spoolandslide
Car: 89 s13 w/ sr20
what kind of response are you looking for?"GodSpeed coilovers are better than the super drifts, buy them right now!"
get some used coilovers, i just got rear jic magics for 80 bucks and im gonna get some fronts for 50 (one is blown but $80 and a cold six pack will fix it at a motorcycle shot)but never skimp out buying bull**** parts from godspeed, (which is a megen kockoff) although megen has now earned my respect by improving quality control, they are still a rip off of apexi
+ i doubt you are going to be doing any drifting for long before you run into a fence
SmithSR
Car: 240sx
k
Endura-Tech
cracker wrote:What does 10 / 8 kg translate into lbs's as???
10k= 560 lbs8k= 448 lbs.
And for all future purposes the conversion is this: take the K number (such as 10) and divide it by .01785 and then you will get the lbs.
crackler
Car: ZOMG JDM TYT3
Thanks. Converting to Kilograhms didn't make any since, even if it was a +n increment (10k = 100 or 10k = 1000, or something like that).
I am used to buying springs in pound rates.
