Good Deal or not
kapetaJR
Car: 1993 240sx. ( Work in progress)
Hi guys
There is a guy i know who is selling a complete RB26 motor for $800 CAD dollars, no harness and ecu is included. Now the only problem is it has a bent rod and it has a blown a head gasket. The Motor has about 85,000 kilometers. Now would it be worth buying this motor and sent it to have an OEM rebuild with a MHG and then sourcing a harness, ECU, RB25 transmission and oil pan. Or i am just better off Getting a motor set with everything included. any advise is appreciated
omgsky
Car: S13
Doesn't sound half bad to me. Rods should be pretty easy to find. How hard was it knocking?
kapetaJR
the motor wasn't knocking it was torn apart. but he said after he saw the white smoke he shut it down.
StricNyne
lol the only problem... to rebuild it properly will run you 3k easily including parts, and u still need ecu and harness
kapetaJR
I guess in the grand scheme of things it's not that bad. But how hard is it to source the harness and ECU, And are there any "rebuild kits" for the rb26, the come with rods and pistons? And would any of you take this route or just get a complete motor or even go for the RB25?
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Sounds like a project you better have 10k plus in the bank and ready to spend!!
Might be worth buying and parting out and making a profit vs fixing.
kapetaJR
rb25drag wrote:Sounds like a project you better have 10k plus in the bank and ready to spend!!
I think i might just look for something else then. I might still pick it up and part it like you said
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I'm with rb25drag. To source all the right parts and harness and rebuild everything will cost you way more than a ready to go RB26. And if you already had a running RB26, an 800 long block would be a hell of a deal if you wanted to sell parts or needed them for yourself.
