good day for the KA
wild_maxx
Car: 90 TT pearl yellow z32
finally got my extra block back from the maching shop. i had supertech 8:1 comp. pistons put in with stock rods and bearings. for the shipping, bore .5mm, hottank block, magnaflux block, crank, and rods, micropolish crank, resize rods (225K miles on them) and completely assemble the bottom end was 969.00 not bad at all to me. heres the pics.
and the supporting goodies JWT programmed ecu for ka24e with 550cc high impedence injectors, z32 maf, 8:1 comp. the injectors are in the pics along with the new oem timing chain parts. i am going with the colt cam stage 3 turbo cam regrind and having the head fully rebuilt. not sure if i am going to have a port and polish done but maybe since it will be off. i will keep everyone updated as the project continues.
veilside180sx
Good luck with your build, should be fun when it's together.=)
Slyce
Car: 89 240
How much would it have been if they didn't assemble it? I'm calling all the machine shops around here and getting prices on the work they do. I'll be assembling it myself though. Did they use a torque plate when boring/honing the block?
Modified by Slyce at 3:20 PM 7/7/2005
epokh
Car: 92 240 HB
92 240 Coupe
02 Sentra
8:1??...plannin' on running a lot of boost? Looks nice!...Just got mine back from the machine shop too...might slap some pics up later...supertech 8.5:1
wild_maxx
it was 500 for the assembly. not sure if they used a turque plate when decking the block.
1WheelWonder
Car: 1991 Nissan 240sx
Awesome man.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Those deep dished pistons are crazy!!
What's your power goal?
wild_maxx
going for 350hp daily and hopefully about 400 tops. i still have to upgrade my turbo. my current one is pretty small. probably go with a t3/t4 50trim. the pistons are 9:1 for the DE but when placed in the E they are lowered to 8:1.
Henry G
Awesome! Can't wait to around town with you in that car. lol
lrb_2000
Car: '91 Nissan KA-T hatch
real quick... where at in WA do you guys live?
WDRacing
From the look of your block, I don't think they decked it at all. Also, I believe the torque plate is used when they over bore not deck since it mounts to the top of the block and simulates the head being torqued down.
I was going to suggest having the head and block decked, the head is alot more prone to beijng warped slightly then the block, but the block looks filthy. You can see old head gasket residue. Any decked surface I've seen looks likie your cylinder bores, basicly new material showing across the whole surface.
WD
Red-KAT
Car: 1995 240sx-se ka24det
Where in WA are you? It would be neat to see yer car.
wild_maxx
i live in ocean shores, about 2.5 hours from vancouver and about 7.5 hours from lewiston. i am moving to pullman, WA next month tho so i will be pretty close to you lrb_2000. should i have to block decked or leave it alone? i am having the head resurfaced and rebuilt.
wild_maxx
so should i have the block decked or not? head is going to be done for sure.
WDRacing
If the head is decked then you might as well have the block done. It will insure a good surface for the head gasket. At a minimum you want the deck area completely stripped.
wild_maxx
i will clean up the deck area as good as i can and see if it will hold. i would have it decked but then i would have to send the whole thing out again and i think its more trouble than its worth right now. any suggestions on what to use for cleaning the deck?
WDRacing
Gasket remover and a scotch brite pad. Don't get the gasket remover inside the bore though. Actually, stuff like PB Blaster and WD40 will work as a cleaner also.
