I called up my state farm agent and he said they would probably give me 50 cents on the dollar if I just took the check. Otherwise they would write the full amound out to what ever body shop I chose. I was quite pissed at this moment. So today I drove out to a state farm location to have them write a estimate and write me a check. On my way there though my front driver side wheel started rubbing my coilover spring like crazy. I jacked the car up the spun the spring so the rim would sit right in between the 2 coils. Then it started to do it again about 5 min. later. Except this time way worse. It was so humiliating, sitting in the middle of the street, trying to move but the screeching was so loud! I finally got in a parking lot and put my spare on. I also raised coilover ring so my front bumper wouldnt be dragging on the ground. I finally got to the state farm place and to my suprise they wrote me out a $775 check. Now I know a shop would charge more than this. And they said if the shop needs more they'll send the shop more money. but im doing it myself. A doors going to run me about $25, I have fiberglass for the skirt, and I have some paint but ill need a bit more for about $75. So I make about $675. While I'm at it im going to be painting my spoiler also.
heres a pic of the spring. you can see the spots were it rubbed. I did accidentally flip the spring around, but that shouldnt matter because it did it on both sides as you can see
I'll probably end up getting some small spacers so they clear. My fronts dont sit how I want them to anyway
