gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sun Jul 12, 2009 11:02 am
The weight is about the same maybe a few pounds more.You can do it by yourself assuming the car is high enough. I have had to do it more than a couple of times because...well...my friends suck. It helps (a LOT) to re-install the transmission crossmember backwards a bit loosely. You prop the rear of the transmission onto the crossmember, lft up the gear box itself and hopefully worm the input shaft in place after a few tries without crushing yourself.It also helps to jack up the front of the engine a few inches. And clock the transmission over just a bit. It sounds more complicated than it is, but if you can get someone to help (or at least available to call EMS should the unthinkable happen) that would honestly be best. Lay down under the car and eyeball it for a few minutes. It will make sense.
