good cheap racing seat for S13
Liquidus
Car: 1990 240sx, 1991 240sx SE
I want a racing seat for my S13 but not sure what to get. I was thinking a Sparco Speed or Sprint, since they are cheap. The problem is that i've heard that a lot of seats are difficult to fit in the S13 due to the stock seat being so thin on the bottom and the low headroom. I'm really tall so i can't lose any head or leg room. Anyone have any experience with these in the S13?
Thanks
book-ends
Car: ???? Nissan 240SX coupe S13
Hello,
I have a Sparco Speed in my S13. The Sprint was too tight in the "lats" section but I don't know if that's because I work out or what! I'm 5'10" and weigh 168 pounds, if that helps.
Also, I used to have the Wedge Engineering brackets AND seat slider, but if I wore a beanie in the winter it would rub against the roof! Since I never adjust the seat forward or back, I just marked it's approximate location and bolted it directly to the bracket. Much better, but still tight with a helmet!
Welcome to NICO.
Axel Grungy
Car: 2001 G20 5spd
pretty much every seat that i know of will sit pretty high in an s13. if im not mistaken i think bride brackets are the only ones that sit low, but those are PRIIICY!!!
aznyo15
Car: 91 240sx hatch
If you want to sit around stock or lower you either need side mount seats or if going bottom mount you have to use bride superlow bottom mounts.
