Postby
cjmirabal1 »
https://forums.nicoclub.com/cjmirabal1-u166362.htmlSat Jan 29, 2011 4:25 pm
I've been searching of good ca18det return oil return lines (turbo to oil pan).
so far I haven't found direct fitlines (possibly due to inexperiance with this type of part)
Does anyone have good suggestions or experience wit certain brands and type lines
Postby
Hoffman5982 »
https://forums.nicoclub.com/hoffman5982-u77367.htmlSat Jan 29, 2011 11:42 pm
Buy your own lines and fitting and put them together yourself. It's the same thing that other companies do, but you won't have to pay for the labor. basically
Postby
OM3GA »
https://forums.nicoclub.com/om3ga-u39603.htmlSun Jan 30, 2011 4:07 am
Typically we use oil resistant tubing such as the Samco stuff or Forge Motorsports. Make sure it has the special oil/fuel proof inner lining and use an EZ coil if you are bending it a good amount.
Postby
cjmirabal1 »
https://forums.nicoclub.com/cjmirabal1-u166362.htmlMon Jan 31, 2011 8:11 am
splintercell wrote:yeah i just used some silicone oil resistant hose... cut it to length and POW! I actually got it from carquest. it was red in color.
