side waz wrote:If they are top feed, they will NOT fit! The SOHC ka's use Top Feed, Low Impedence injector's while the DOHC uses Side Feed, High Impedence injector's.
You would have to get a new fuel rail or custom make one and then you'd need resistor's for each injector as well.
It can be done but you'd prob be better off looking for FC T2 or FD injector's. They are side feed, H/IMP and fit right in. All you might have to get are new collars.
They'll fit his car just fine. He's running SOHC (scroll up). Also, I was under the impression that the sidefeeds were LOW impedence and the top feeds were HIGH impedence, as specified in the F/S ad link above (RX7 High Imp. top feeds)
