Razi wrote:Liking the spacers, the spoiler, not so much.
I think your car looks way cleaner without it.
As for the engine, pull the spark plug wires one at a time while the engine is running, and if you pull one that doesn't make a difference, the problem is at that cylinder.
I'd pull the injector and check to see if the o-ring is okay.
I learned that you've got to lube the heck out of it if you want it to slide in easily without ripping the o-ring.
Interesting as how replacing the injector fixed the problem for a while.
Is the injector new or used?
I personally love the spoiler. Its enough while still being clean. I'll def do the spark plug troubleshooting and then check the o ring on the new injector. My dad was the one who put it on so idk exactly what he did. And yea it doesnt make sense because it ran fine for about 20 minutes. and the injector is new btw.
alms24sebring wrote:1) ur tires are soooo close to the fender, its ganna rub over the smallest bump
2) I, ubnlike Razi, love the spoiler. Its low and sleek.. looks great I think
3) I would suspect a head gasket. What color smoke? Check coolant level and trouble codes, they mite tell you something
I still have the cut away the lip of the fender, I think it should be fine. I'll test it buy jacking the wheel up before I go for a ride though.
I also love the spoiler. Thanks
I'll keep in mind the head gasket. The smokle was just your average smoke color. Not black or really any darker. And certainly not a different color.
I'll be sure to check this things tommorow and let you know. I appreciate all the help! Thanks
