Good Alignment Shop; Chicago
Chicagos13
Car: 1992 240sx Fastback
Need an alignment coming up after I get my Tein tie rods installed. Any suggestions anyone near the Chicagoland area? Or should I go and get the lifetime alignment at Firestone? Just not sure where to go. I need one now and I'm sure it will be much worse after the install. Thanks.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I'm sure I'm speaking for everyone when I say an alignment is an alignment as long as they put the wheels into the camber/caster and toe-in/toe-out specs that you want or that the factory recommends. If you just got tie rods installed, stick with factory alignment specs. Doesn't matter where you go, but if you can get a "lifetime" alignment go for it.
