I'm from Hong Kong,
I'm using SSAC SS manifold since May 2006, I'm using a China made turbo that the EXACTLLY same as ISIS 3871, ( a China friend help me to buy it) and I'm EWG it too.
I know that the SS manifold is China made, but I brought it from ebay,
by the time I brought it, there is no local seller selling China made parts.
I know that China made SS manifold is quite easy to crack, so I use a thick piece of SS bar to brace it,
it works fine and no crack and today 2012 I'm still using it,
I have been using 2 X S14/S15 stock turbo on it with no problem,
In 2011, I have upgrade the turbo to ISIS 3871, it is renamed turbo from China,
but it works very well...if you EWG it,
I have found that if i DO NOT EWG it, it can't boost over 15psi and will drop back on hi rev,
The problem is on the round interrnal flip door swing angle VS external push bar posistion angle ....something like flip door swing angle VS accuator rod travel length
(the bar that link and welded to the flip door, and with a small pole for joining the accuator rod end with a C clip)
The angle it weld to the flip door is 30 degree off, let say if it is a clock, flip door pointing at 6 o'clock, the push bar is pointing 4 o'clock, the accoator is locate under 9 o'clock.
once it build up enought exhause back pressure, it push open the flip door,
try to think if the flip door pointing at 5 o'clock , the push bar pointing at 3 o'clock, and the rod travel is almost 0, the flip door movement is not well control by the accuator spring pressure.
I have compare the push bar weld angle, to a genuine garrett S15 turbo, they are different, I know that If I cut the bar and re-weld it, it will works fine, but the accuator mount might need to redo, the accuator need to be seated to a upper position, and I want to try EWG, so I go EWG.
the accuator it comes with is around 7 psi, I have tried upgrade the accuator to a 15psi accuator, it didn't works.
So I make it EWG, and it works much better than the standard internal accuator set up, boost come eariler.
and keep steady , keep until it hit rev cut.
The ISIS 3871, I heard that is good up to 1.5 bar of boost, I have been running at 1.4 bar on my CA18,
One of my friend in China, he had a S14 SR20DET drift car, mod the ISIS 3871 to a top mount manifold, runing at 1.2 bar with a lot of abuse, always hitting the rev limiter,
the ISIS 3871 finally got cold start smoke after a year of abuse, and he can return the turbo to the factory for rebuilt free.
Photos of 2006 set up, new SS manifold with S15 stock turbo
Photos of ISIS RS3871 with it's standard internal accuator
See the swing bar angle different from the stock S15 turbo ?
Photos of 2011 setup, still that old SS manifold with ISIS 3871 turbo, 38mm EWG.
My frind S14 SR20DET with the ISIS 3871 mod to top mount
