superDorifto »
https://forums.nicoclub.com/superdorifto-u29662.html
Mon Oct 24, 2005 8:23 pm
if the bearings are installed with the right tolerances as specified in the fsm you should be fine. the machinist should be able to take care of those details for you, but if you want to do it yourself you can just have him do the actual machining and mock up. actually installing the new bearings is relatively simple...theres a good thread on ka-t.org in the favorites section. im rebuilding my motor with new clevite bearings, and took the crank and the block to a local machinists. i paid him 20 bucks, and he measured every journal and bore for me with his tools, which are far mor accurate than my own. now i now that everything is still within factory tollerances. however, reliablity and horsepower is really a game of how much do you want to spend. less now generally equals more later. im only doing new rings and bearings, so i might have reliablity issues later, but then again im only shooting for 250 hp. hit me on aim if you still have any questions..
