OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Thu Jul 23, 2009 5:22 am
Google is a good start..... It won’t show you much. The reason is because I think only 1 has successfully been finished. The person who did had to...
-Remove and relocate the frame rails which now affect the backspacing of the front wheels.-Modify the firewall-Build a custom crossmember with custom mounts (of course), but relocate the steering rack some (hard)-Build a one off, custom, intake manifold because the stock one is so tall, the process for this took the builder weeks to get right.-Transmission adapter plates / custom bellhousing, transmission crossmember.-Then all the plumbing, wiring, fueling.-Oil pan fabrication, pickup
The issue is that it’s a 90 degree V8 with 4 overhead cams. If you try to drop it in the heads will almost hit the frame rails, so no header room, they just clear in the z33 chassis. The people who build a VK56 S-Chassis was an experienced weld/ fabricator. And it took time a long time to figure out. In the end it’s cool, very cool. But at the same time it’s not worth the money and fabrication. And other then supercharging / turbo...... the performance parts market for these are very limited.
