Gonna be buying S13 manual parts tonight for my s14
gepeto
Car: 1995 S14
Can you tell me if it'll fit on my s14 for a manual swap?
It's in french (pasting the post) but I translated the hard parts
Thanks guys!
Inclus:- Transmission manuelle (manual transmission)- Flywheel- bolt de flywheel- Pedale de clutch (clutch pedal)- Pedale de brake (brake pedal)- Master cylindre de clutch (neuf dans la boite) (new in box master cylinder)- Slave cylinder (neuf dans la boite) (new in box slave cylinder)- drive shaft (I have an s14 manual driveshaft anyways)- Ligne de master cylindre complete (clutch line)- Cross member de transmission (crossmember)
