Going with MAPS
sl87
Car: nissan 240sx
So my build is almost done. Im gonna be running a MAP setup on AEM EMS. What do I do with the MAF wiring? Just tuck it away? Also, can anybody help me with the difference between 1, 3 and 5 bar setups. I dont quite understand it. Im gonna be running 810cc injectors and wanna shoot for 450hp at 20psi give or take. Any other info you need from me will be given. Thanks
240_SeX
Car: 1992 240SX SE
You can use the MAF wiring to wire the MAP if you want or you can just tuck them.. http://forum.aempower.com/foru....html
That shows bolth i belive.
The sensor pressure readings are measured in bars. the 1 bar will read up to one bar, the 3.5 up to 3.5 and so on. however they are only accurate to something like half of their max reading. if you plan to run 20 psi you will be fine with the 3.5 bar sensor.
What are you using for injectors, i`m looking for a base map.
sl87
Car: nissan 240sx
Thanks for your help and for the website. I'm gonna be running 810cc inj. if that answers your question. I dont have the EMS just yet. Need a couple more pay checks. AEM standalone is so much money!! but heard its worth every penny. I just want to figure everything out before I actually get the EMS.
240_SeX
Car: 1992 240SX SE
It is well worth it
