Going VIP and need help
NICO's V.I.P. styling forum.
Ke0
Car: Fuga
OKay I own a 06' M35x and I know that the factory specs are 18x8. I'm looking at MRR HR3's and the size I was thinking about getting for my car was 20 X 9.5. I notice alot of M's are going with 8.5 in the front is that because its a staggered or will it rub in the front if it was 9.5?
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
Welcome to the VIP Forum!
I'm pretty sure that's reall going to come down to what offset you are looking to go with. Any ideas as to what that may be?
AZ89two4Tsx
You ain't gonna be VIP unless you do some fender work.
Ke0
Car: Fuga
the offsets 35mm
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
You will need to do some measuring.
http://www.1010tires.com/WheelOffsetCalculator.asp
Big C
Car: 03 350z
Yes, 20x9.5 HR3's will work all the way around.
owinbush
Car: 1998 Inifinit Q45
2009 Nissan Cube
Pretty much all the MRR stuff is gonna be relatively conservative for you car. 35et might be better than stock but you're not gonna get the agressive fitment typically associated with VIP.
Go with the 9.5s and plan on doing a roll and possibly getting a set of spacers to get the fitment right after you've run them without and do all your measurements to see how much of a spacer you'll need.
Return to “VIP Forum”
