A few things...
The stock wheels on the G35 19s are 8" front, and 8.5" rear. I'm not sure the 30s will fit properly...can anyone confirm?
Using the sizes:245/35 -19 front275/30 -19 rear
The front tire will be 6mm taller than the rear...
Stock size difference has the rear 16mm taller than the front.
My solution was to use:
255/35 -19 front275/35 -19 rearDifference of 14mm.
But I'm not sure if the front tire will rub or not...if you go down to the 245 for the front, the difference increase to 20mm. Not sure if thats too much for the VDC or not...
Check out this website to play with the numbers:
http://www.bigcustomwheels.com/info_specs.jsp
