Kenrik wrote:No it's not... I said you can run a JWT without a SAFC II What the hell are you talking about? The JWT ECU is an off the shelf product not 100% customized for the specific engine! It automaticly corrects the settings for what it knows is on the car just the way a stock ECU would which is not always the most efficient..
I said to TUNE the A/F ratio you would need a S-AFC II There is a difference between tuning and letting the JWT ECU make it's own adjustments using the stock o2 sensor you have in your car.
Why spend that kind of money on such a set-up, that in the end fights itself?
First off JWT ECU's can be custom tuned. It's a bit difficult for most as it would require a lot of back and forth, unless you happen to be able to drive down to JWT and have them tune it. But secondly, while they are a bit conservative, the tune is not that bad. By tuning it more aggressively, you're not going to make a ton of additional power. I've heard of several reliable 350 HP KA's (at 14 psi) and all ran on a standard JWT tune using 50# injectors and a Cobra MAF.
Keep in mind that the OEM and JWT ECU's both ignore the O2 sensor under WOT. Both make adjustments based on the O2 signal at part throttle and idle. This means, that even with a piggy-back, it is still trying to acheive the ECU's desired A/F unless you are at WOT. So the only place any piggyback would truly me makiing a difference is at WOT. The exception may be the new E-Manage Ultimate which provides it's own injector signals. This is more of a hybrid piggy-back anyways.
Honestly, if you are searching for these minimal amounts of power by piggy-backing a JWT ECU, then I would seriously look at planning the hardware aspects of the turbo system better than to go through the trouble of trying to fine-tune an A/F for power. The dynotime needed for such a thing, along with the piggy-back system are probably going to be more expensive than the cost of better hardware. Not to mention you can do it at a much safer level of ECU tuning.
