andrave »
https://forums.nicoclub.com/andrave-u6358.html
Fri Jan 30, 2004 12:14 pm
you will need some sort of fuel management no matter what boost level you run, even if you wish to keep the stock injectors. I wouldn't run anything over stock, including an FMU, with a worn out stock fuel pump. I don't know what you mean about using the stock Z31 manifold, you know that it is a six cylinder, right? your car is a 4 cylinder, I don't think there is much hope there.Or are you talking about a stock ka exhaust manifold with a flange welded? this is equally weird since the design of the ka manifold would not allow you to just weld a flange at the end of it...besides welding a cast part isn't a good idea and its difficult to do well.for the oil lines you need both an oil FEED and an oil return. For the oil return you must remove the oil pan, drill and tap it, and then run the hose. I have seen guys use heater hose but I'm using stainless on mine. Its going to my turbos and its going to be down by my manifold and downpipe, that area is hot and stainless has a good safety range around really hot stuff. I've read that you should try and keep the feed/drain lines within 30 degrees of being vertical.
