jimbyjimb »
https://forums.nicoclub.com/jimbyjimb-u93878.html
Fri May 29, 2009 5:41 am
I absolutely agree with you, Max. 100%. It is so easy to see where, when buying a car like a Q or most MB or BMW products, especially those of yore with metal and leather rather than plastic and vinyl, the extra cash goes. But it is paid for. Alot. Whereas, I see, constantly, daily, many a cheap Honda Civic/Accord that is 15-25 years of age, has had no major mechanical issues outside of normal maintenance still out causing trouble on the roads. Simplicity works, such, the most mechanically simple cars on the road are often the most long-term reliable and inexpensive to own vehicles. Ford CV's, although seemingly most hated here, are one of the most durable, dependable and reliable cars to own along with being cheap to own as well. What with modern technology a new cheap front driver has many gizmos and a significantly improved ride, performance, reduced noise levels, blah... Technology has also allowed the very simple CV, basically a run of the mill ladder frame, solid-axle design like any 60's, 70's American, to ride smooth and be quite comfortable. Sure the cheesey interior blows and the exterior needs repainting every 7-10 years, but is stil phenominally less expensive to own. Also, it should be noted that most old Honda products have a higher resale than most Infiniti products of the era. A 92 Accord in decent shape will fetch more in Seattle than any 92 g50 or g20 in near perfect shape. The bar has raised, and a newer V6 Accord will outperform our aged Q's in most ways and be sufficiently less expensive to maintain once purchased to justify the slightly louder freeway noise and lack of metal and leather inside. Point A to B is a vehicle's main purpose, and out of every car I've ever owned the Q is the worst by far at achieving it's primary objective efficiently and inexpensively. That being said, when it does achieve it does so with suppleness and comfort. Keep in mind my Q was exceptionally well mechanically maintained and I myself maintain it well in accordance with tradition. In terms of now, the Q is simply outclassed with the extreme efficiency and power output of much smaller vehicles to which technology has improved immensely since the Q's birth. Given the choice, I, obviously, would not be a Q owner, as I would rather compromise in certain areas for the primary objective to be more economical to obtain. Hence, my 76 Toyota pickup complete with Ethanol-resistant Carburetion, emissions exemptness and rediculous inexpensivity and simplicity. I am, however, a simple man.
