Going to dyno coming Tuesday..
JDMSIL80
I'll be doing a baseline run with the exiting mods, to find out the differences after my HKS cams (264int/272ext) installed and tuned with Power FC.
Conservatively, how much power should I be putting down on the wheels at the moment? Here's the current mod list:
Garrett GT28R444cc GT-R injectorsHorsham stage 3 chip (mapped up to 17psi)Blitz I-D color EBCFET coil packXS Power FMICXS Power turbo manifoldXS Power down pipeMegan Racing exhaustHKS SSQV recirculatedHKS Power filterZ32 MAFWalboro 255 fuel pumpBone stock motor
boost_boy
JDMSIL80 wrote:Conservatively, how much power should I be putting down on the wheels?
You will probably hit around 250-270 to the wheels.
Dee
JDMSIL80
^Cool, hope I can lay down those numbers.
Once the HKS (264/272) cams are installed and tuned safely up to 20psi with Power FC, do you think it can hit over 300whp?
Modified by JDMSIL80 at 11:16 AM 5/21/2006
c-rad
Car: 1991 Nissan 240SX w/CA18DET
JDMSIL80 wrote:^Cool, hope I can lay down those numbers.
Not with those injectors. 444cc's will set your limit to about 275-280. The turbos max efficiency is 18psi and it would be stretch to hit 300 with it.
JDMSIL80
So with the cams installed, does it mean I need to get bigger injectors unless I run below 18psi?
c-rad
JDMSIL80 wrote:So with the cams installed, does it mean I need to get bigger injectors unless I run below 18psi?
Personally, I would get some 550cc's. I would much rather run the 550s at 80-85% duty cycle than the 444's at 95-100% duty cycle.
Boostin_S13
Car: S13
offtopic but do you have any pics of how your HKS SSQV recirculated setup is?
JDMSIL80
Boostin_S13 wrote:offtopic but do you have any pics of how your HKS SSQV recirculated setup is?
240DRFT
man thats a fatty hose lol the ca looks good though, wish i had one
Boostin_S13
Car: S13
Nice! So what happened at the dyno? Or do you mean Tuesday 30th?
JDMSIL80
Here's the thread: zerothread?id=176580
Boostin_S13 wrote:Nice! So what happened at the dyno? Or do you mean Tuesday 30th?
boost_boy
This is what happens when you create different threads about the same subject. In the future, any new threads that has bled over from a previous thread will get EXECUTED[/B.
Dee
