mello88 wrote:oil in the compressor outlet and TB is probably from PCV blow by, but like you said the oil seal might be going out/gone. I pressurized my turbo oil port with 10 or 20psi of air and you could hear it leaking out of the compressor inlet pretty badly. My turbo had a bunch of oil coming from the turbo outlet when I got it also. How much shaft play does it have?
Dunno what the orange sludge is but I would pull all the plugs and coils out and clean everything. Sounds like it might have been oil + rusty water. Guess it's possible it was some kind of anti seize on the threads but I would take off the valve covers and check them out, and pull off the oil pan and check it out also.. Take out the plugs and shine a light into the cylinders to see if there is any junk in there.
No shaft play whats so ever. But the egine definately was lightly modded as there is a greddy vacuum t for a previous boost gauge and the ecu has some sort of racing sticker from japan on it. LMAO. But all parts are stock as far as turbo and elbow go.
