When I went to go check it out it ran fine passed idle. He slid it to show me that it ran fine but idled like crap. He had to stay on the pedal to keep it alive. Told me it was vac or boost leak. The day after I bought it I went hunting for this "leak" but didn't find a thing. Motor was all rusted and beat blowing black smoke like crazy. Pulled the plugs and they were fouled to hell so I thought it nedded a new head gasket. Since I was there I figured might as well just rebuld the entire motor.
I pulled the motor out and it took me about a year to finish since I machined it at school and assembled it in my garage.
By the time I was done with the motor this is what it had;
- Butterfly delete (Made sure everything was plugged up nice.)
- Surfaced head
- Decked Block
- Honed .020 over
- CP Pistons
- K1 rods
- Tomei 256 Poncams
- T25/T28 Isis turbo
- Trust timing belt
- Clevite main Bearings
- ACL Rod Bearings
- OBX manifold
- New OEM Oil Pump
- New OEM water pump
- New PCV valve
- Oil Catch Can Between cover and intake
Dropped the motor back in and it still ran the same. Had to stay on the pedal to keep it alive and smelled rich as F***. Automatically I figured it was going to be a sensor or a couple sensors that were causing this. Again I went hunting to no avail. Replaced coolant temp sensor, TPS, 1m ohm Knock Sensor bypass (conector was gone), ignitor, and drop resistor. Cleaned out the Idle valve set up and used all new OEM gaskets...no leaks and no change.
After that I had saved up to get myself a Nistune board. I looked for the serial number on the ecu cover that nistune needs but it was faded as hell and I couldnt see it. So I thought I'd open up the cover to mabe see if there was a number inside I could use. What I found was a Socket with a ROM chip as well as "550cc and Z32" written on the inside cover.
Frustrated at this find instead of getting a new ecu and nistune, I bought the following.
- DW 550cc injectors
- Nismo FPR set to 40psi
- Walbro 255 pump
- z32 MAF
- Innovate LC-2 Wideband
Changed everything out still ran like @ss. I've gotten it to idle with no load. I took it out for a spin a couple weeks ago around the block and there was no throttle response under load. Had to clutch kick to get it up to speed (Guessing limp mode here?).
A Couple days ago I go to start it up and now it won't even idle. I've had to feather the throttle to keep it alive. If I open it too much it backfires through the intake (very bad). Pulled off the MAF connector and it idles perfect at around 2000-2500 rpm with a stoic a/f ratio but dies when the throttle is messed with or the maf is plugged back in. It's a brand new Isis z32 MAF too and I've tripple checked that the wiring is done right. I've changed out my plugs numerous times and ckecked all of my sensors too many times. ECU shows code 55 also. I still don't know what it could be and I don't want to give up on it. This is my first post on here but I've been on this forum a lot searching for possible answers.
I'm guessing it's a Sh*t ROM chip, a bad harness, or a bad MAF. It's been almost 2 years since I've bought it and I want to drive it already.
Any help would be greatly apreaciated
